datasocket server too slow
i'm having an aquisition system running on one computer that needs to feed the data in real time to another computer at ~40mbyte/s to process. i'm running a datasocket server at the aquisition computer and have the second computer read packages of data from the datasocket server. but turns out it takes close to 2 sec to write 1 sec worth of data onto the localhost datasocket server. the two computers are connected through a private 2Gbyte local private network, so LAN speed is not an issue. is there some trick i can use to configure the datasocket server or client? or what is fastest way to stream data between two computers?
(2,960 Views)
Before data sockets, I got excellent results with a similar type of client/server app by just using the TCP/IP VIs. Look at the Data Client and Data Server examples in Comm example folder.
I believe I was streaming results at ~300 kS/sec within a 100 Mbs network connection!
Hope this helps
Robert
(2,960 Views)
i used tcp/ip. and after some testing, was able to get a 30mbyte/s rate! thanks!
(2,960 Views)
