04-30-2006 02:33 PM
05-01-2006 10:59 AM
One thing that might be causing that error is trying to use a reserved word for the name of a field or the table itself. Access has hundreds of reserved words. Could this be your problem? One way to check is to append a prefix to the names of all your fields such as "abc_" {don't actually use the double quotes, they mean something specific by themselves}. If this works, chances are, you were trying to name a field with one of the reserved words and Access didn't approve.
If that doesn't fix the problem, enclose a screen capture or VI.
05-01-2006 01:15 PM
01-08-2008 02:59 AM
