database connectivity in labview?
when I select the OLE DB provider is "microsoft OLE DB provider for
ODBC Drivers",I can write to database,but I can't read from database
using data connectivity toolkit?
i use the SQL language
SELECT * FROM motor WHERE serial="aaa"
the error is :
"error-2147217904 occurred at conn Execute.vi-fetch record.vi(myvi).
possible reasons:
Invlid string:specified field does not exist or contains an
unsupported character"
but when I select the OLE DB provider is "microsoft JET 4.0 OLE DB
provider" in UDL file,i can read the record using the same language.
(3,882 Views)
Is it possible the table you are doing a "Select" on contains Chinese characters? It's possible the driver you have selected does not support Chinese characters.
One suggestion would be to open the database (or table) in Microsoft Access and do a quick visual inspection of it. You can check for the spelling of the "Serial" column and see if it contains any Chinese characters.
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(3,882 Views)
Archimedes wrote in message news:<506500000005000000D6060100-1042324653000@exchange.ni.com>...
> characters.
thank you for your suggestion.
I have checked the tabel,it contain no chinese characters,my tabel is
below:
serial DT efficiency pf stray
abc 2003-7-2 17:25:09 .02168 1202.556 12.5
I stored data in microsoft access database (.d
b file) and i use the
same SQL language,but get diffrent result,"microsoft JET 4.0 OLE DB
provider"can work,but "microsoft OLE DB provider for ODBC Drivers"
can't read,I don't why?
appreciation for any suggestion
(3,882 Views)
Try using different delimeters.
Try;
single quote (')
Number sign (#)
Not all DB use the same delimiters.
Ben
(3,882 Views)
Ben wrote in message news:<5065000000050000004F070100-1042324653000@exchange.ni.com>...
> Try;
> single quote (')
> Number sign (#)
> Ben
thank you!i have solve the problem by using the "the single quote".
(3,882 Views)
Cool!
Thanks for the feedback.
Ben
(3,882 Views)
