database access problem
    I have a problem with access operation.The error is syntax error.First I transfer some different parameters to string then I contact them.
The result expression(red point in diagram) to DB tools Execute query.vi's sql query port is
UPDATE AnalogInputVoltage SET Max=8.00,Min=7.00,Units=0,Terminal=0 where Channel='Dev1/ai5';
And ,I have checked access,There is no prob.
The syntax error always show.
*The best Chinese farmer*
(2,712 Views)
Parenthesis maybe?
UPDATE AnalogInputVoltage SET (Max=8.00,Min=7.00,Units=0,Terminal=0) where Channel='Dev1/ai5'
When they give imbeciles handicap-parking, I won't have so far to walk!
(2,707 Views)
I haven't used SQL expressions in Labview, but in many other database
implementations Max and Min are reserved words...
HTH,
Mike
(2,672 Views)
