Can't see Vision function pallet in LabView 8
Hi all
I just install LabView 8.0 🙂
I also install after that :
Motion Assistant 1.2
Vision Module 7.1.1
In the function pallet i see only the motion pallet but i cant see the vision pallet !!!
i was already see all the help about how to edit the function pallet in  LV8
and all the things related to the .mnu files...
i also check in the install process of the Vision Module that i install the support for the
"Latest version of LabView" but nothing help...
i still want the "natural" way to see the Vision function pallet in my LV8.
PLEASE HELP !!!
Thanks in advanced
Mor
(3,048 Views)
Hello
 this link (do not forget the visutil utility) was useful to me. the vision palette is OK in Lv8.
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
(3,042 Views)
while (True) {
       Alipio , thank you
🙂 thank you for the quick help.  Mor.
(3,035 Views)
I had the same problem. There may be another way, but after calling
tech support, they had me uninstall Labview and the Vision Dev Module.
Then reinstall Labview, then the Vision module. Apparently since I had
the module installed and was using it with VB then installed Labview it
didn't get registered properly.
HTH,
Mike
(3,032 Views)
