database SELECT SYNTAX
Before doing your select statement, have you selected the database to use ?
Try to make a small vi that demonstrate what you are doing and post it here.
Message 11 of 20
(3,783 Views)
Edit: I didn't see your other post so the semicolon is probably not the problem. What does the server error log say?
LabVIEW 2012
Message 12 of 20
(3,779 Views)
select top 1 id from SensoresIR1 order by id desc
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 20
(3,756 Views)
Just going back to your original post where your SQL statement didn't work the reason is as follows...
SELECT id FROM SensoresIR1 WHERE id=36151  = ERROR!
SELECT id FROM SensoresIR1 WHERE id='36151'  = GOOD Smiley Very Happy
ie. you just need to put apostrophes around the value that you want to search for - this syntax will work of MySQL and MS SQL databases.
Chris
Message 14 of 20
(3,744 Views)
Chris
nomade42k, I would be interested to hear from you if that worked. You do not have to quote numeric datatypes although you can. I can not speak to MySQL or MS SQL as I only use PostgreSQL. I know that MySQL has some funky syntax. Is id a string? That would totally explain the error Smiley Very Happy
The reason I did not think it was a string is because you said it is automatically assigned by the server which implies it is an integer sequence.
LabVIEW 2012
Message 15 of 20
(3,740 Views)
Hello!
here I leave you my block VI and the DB with its columns (in spanish)
It still doesn´t work...
Message 16 of 20
(3,726 Views)
I think you need to quote your time string. I don't know if MySQL uses single or double quotes.
LabVIEW 2012
Message 17 of 20
(3,708 Views)
Accepted by nomade42k
After looking at this some more I notice you are using the select vi. You are sending the entire SQL statement to the where clause input. There is a vi under advanced called 'execute query' which you will want to use when you are building the statement yourself. The select just requires the table input and an array of columns.
Try something like this. You may need to change the quote from single to double (or remove the quote if the DB tools is smart enough to quote the parameters. I have never used it)
LabVIEW 2012
Message 18 of 20
(3,703 Views)
Err message disapears after add 'where' in my case 😉
Message 19 of 20
(3,302 Views)
If memory serves, the Select function adds Where automatically (if the string is not empty), so you'll get a double Where in this case.
/Y
Qestit Systems
Message 20 of 20
(3,286 Views)
