data types in event structure?
(Look at picture below)
How do I make the -100 constant to be in double?
Is the problem above the reason that the scale always shows 0 as minimum?
EDIT:
Sorry! Smiley Very Happy
attaching file....
Message Edited by Johan.svensson on 07-25-2006 12:39 AM
Message 1 of 8
(4,276 Views)
Hi Johan
There is no picture..
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 8
(4,269 Views)
Right click on the constant . Select Representation fro the popup-menu followed vy double or whatever other type you want.
Mario
Message 3 of 8
(4,259 Views)
I've tried that now and of course the data type changes, but the tunnel (i belive it is caled tunnel) does have q white spot in the middle which the other tunnels don't
Does it make any difference? I mean, about solving the problem with "minimum scale" property node
Message 4 of 8
(4,255 Views)
How to change the type, cubano already described.
Basically it should set the scale, because the datatype is converted (you should see a conversion dot). Maybe you have autoscale activated (I assume you try to set the scale of a graph control), what could result in the described behaviour.
Using LV8.0
Message 5 of 8
(4,253 Views)
Yes this makes a difference - the one you described, passes a default value to the property node. You have to wire these from the inside - this could also cause the described behaviour.
To avoid this, rightclick these terminals and deselect "default values if unwired".
Using LV8.0
Message 6 of 8
(4,250 Views)
That's ok.
In this case an integer input to a floating point property node will not cause any alarming errors.
That white dot in the middle just denotes that you have selected 'use default if unwired' option for that particular tunnel.
if you connect inputs to that tunnel in all event cases, this white dot will disappear.
if you leave it blank, a default value will be assigned from that case to the tunnel
Message 7 of 8
(4,247 Views)
Thanks!
Problem solved...
There was an unconnected wire in timeout event.
When all got connected and datatype double the scaling of the graph works perfectly
Message 8 of 8
(4,242 Views)
