data to sql server using labview and labview sql toolkit
Hello everyone,
I am using mssqlserver 7.0, labview 6.1 and labview sql toolkit.
I am getting error while i try to store (large) data of size more than 4000bytes. Has anyone come accross such problem .
Looking for your solutions or suggestion for the
above said problem.
(2,924 Views)
Check if the threshold is actual 4095 or 4096.
If so it is probably a default size of the field you are trying to write. If so, change table properties.
Ben
(2,924 Views)
