data lost in Event Structure
Occasionally I'll have data that is lost in an Event Structure, or even subVIs that are not executed within events that I know are executed. What would cause this? I have attached a screenshot pointing out an example where I have Execution Highlighting on.
Edit: file now actually attached
(2,992 Views)
Accepted by topic author bmihura
Check to see of you have one tunnel on top of another.
(2,969 Views)
One likely cause is a tunnel on top of a tunnel.  With the event structure if you accidentally create overlapping tunnels you get the less than desirable "Use Default if unwired" and the old F out every time.
Delete the tunnel and re-wire
"Should be" isn't "Is" -Jay
(2,968 Views)
Yes, that was it. Thanks.
(2,950 Views)
