Alarm system
I edit an alarm program, the problem is that i cant run it continuously. I had to restart the program and start it again for it to work. How do i make the alram to able to reset the system
(4,618 Views)
Hi lame,
how many threads about burglar alarm systems do you want to start? Why not keep it in one place?
Your VI
- needs some timing. No need to check alarms several times each microsecond.
- needs a way to reset old alarms. Right now you can't... (Hint: you're using shift registers. They are uninitialized...)
- has an "interesting" password check... No need for using the exactly same password when "retyping"!? No need for retyping the password when the VI is started again!?
- needs a loop to run continuously...
(4,607 Views)
I dont get what you mean by the shift register thingy.
(4,588 Views)
Hi lame,
when you don't know about "uninitialized shift registers" you should go through LabVIEW basics...
(4,586 Views)
How do i make the vi run without typing the password
(4,553 Views)
Hi lame,
what's the use of a password when you don't need to type it when you start your program???
(4,523 Views)
What i mean is, that when i start the vi and when restart the alarm, i dont need to retype the password again. How do i do that?
(4,492 Views)
