data binding with DataSockets
Sorry about the bad link.  The server it is on is an internal one.  I hope you find it helpful.
And I will fix that link soon.
Justin Parker
Product Support Engineer
Message 11 of 17
(1,833 Views)
The 3rd tier VI programmatically sets the DataSocket URL of an indicator.  This can be seen as a data item in the DataSocket Server Diagnostic screen.  When the VI ends, each indicator is reset to "dstp:\\" which should remove from the DataSocket Server.  However, I noticed that the last DataSocket URL remains listed in the DataSocket Server Diagnostic screen.  It may change data type (floating point to integer) but it never goes away.
After the VI quits, if I use the DataSocket Select URL VI to examine exising data items on the Server, I see an inconsistancy.  Under My Computer, it states that no DataSocket Server exists.  But under the computer name in My Network Places it shows the DataSocket Server with all the data items just like the DataSocket Server Diagnostic screen.
Why the inconsistancy?  Is there a better way to disconnect the DataSocket from the indicator and remove the data item?
Message 12 of 17
(1,803 Views)
When you refer to checking under My Computer for the DataSocket server to exist, where exactly are you looking? What does it show you in the DataSocket Server Diagnostics screen?
-Zach
Message 13 of 17
(1,789 Views)
When examining the selection screen produced by DataSocket Select URL VI, under My Computer, it shows no DataSocket Server running.  But under the local computer name in My Network Places (in the same selection screen) it shows a DataSocket Server running containing all the data items specified in the DataSocket Server Diagnostic screen.
DataSocket Server Diagnostic screen shows all the DataSocket URLs I have activated.  However, when I deactivate them (resetting the DataSocket URL of an indicator to "dstp:\\") the last DataSocket URL is listed as existing.
Message 14 of 17
(1,783 Views)
Have you tried this on any other computers to see if it is specific to your installation? Also, do you have other versions of LabVIEW between 7 and 2009 that you can test?
-Zach
Message 15 of 17
(1,776 Views)
I've tried this different computers with different versions of LabVIEW and have the same result.
Message 16 of 17
(1,733 Views)
What versions have you tried?  There have been a lot of changes made since 7.1. Even going from 7.1 to 8.0 changed many things so it is useful to know which version actually broke what you are trying to do. Also can you post a simplified 1st tier and 2nd tier VI which replicates the issue?
-Zach
Message Edited by iZACHdx on 05-07-2010 11:44 AM
Message 17 of 17
(1,716 Views)
