Mathscript Syntax Error
Can anyone let me know what the syntax error is in this
if((A>=1.70)&(A<=1.71))
A=1
if((A>=1.34)&(A<=1.36))
A=1
if((A>=0.925)&(A<=0.935))
B=1
if((A>=1.305)&(A<=1.32))
B=1
if((A>=1.935)&(A<=1.941))
C=1
if((A>=1.72)&(A<=1.73))
D=1
E=1
if((A>=1.65)&(A<=1.66))
F=1
if((A>=1.29)&(A<=1.30))
G=1
if((A>=1.0)&(A<=1.05))
H=1
else
I=1
end
thanks chris
(3,879 Views)
Accepted by topic author chrisharris
I assume you want all of those if's (except the first one) to be an elseif.  If this is not the case, then you want to put an end after each individual if.
Also, it's not a bad idea to throw a ; at the end of each statement.  (Not the lines containing if, elseif or end)
Also, you probably want to use && instead of &.  I'm not sure if mathscript differentiates between the two, but I know some languages do.  The help file for mathscript uses &&, so I'd go with that.  Anyone care to confirm if there's a difference?
Message Edited by elset191 on 05-07-2010 10:19 AM
Tim Elsey
Certified LabVIEW Architect
(3,866 Views)
Thanks for your help with this,the coding now works. Also && works as well but I think a single & also works.
Chris
(3,858 Views)
Some information about the difference between the & and && operators is presented in this thread.
Grant M.
Senior Software Engineer | LabVIEW MathScript | National Instruments
(3,846 Views)
Thanks for the link, that's some good info.
Tim Elsey
(3,836 Views)
