data acquisition of CV7-V wind sensor under labview using NI 9403
hello
I want to measure a numeric type RS232 signal at the output of a CV7-V wind sensor (attached PDF file)
I used the module CDAQ 9191 and NI 9403 under NI MAX and I got the result on the attached figure
how I can retrieve the information from this sensor under labview using CDAQ  9191 and 9403 Module
(2,748 Views)
I forgot to send the manual for CV7-V wind sensor  in PDF file
(2,745 Views)
