Showing results forĀ
Search instead forĀ
Did you mean:Ā
dat files
How can I programm my file.vi in order to read each byte of a file (.dat) ,about 80Mbyte, and then take each byte out through the serial USB port. Thanks
(3,601 Views)
Hi JOENASSAR,
you can read the file byte by byte. See the attached image for an example.
Hope it helps.
Mike
(3,579 Views)
Hi Mike,
Not adding delay inside FOR loop will not be problem or  is it required only for while loop??
pls bear with my question..
(3,574 Views)
Hi G K,
no it's not only for while loop, but i think in this case the write function will break the process to also give the processor time for other tasks.
Mike
(3,572 Views)
Mike thanks for the reply and you are right... ( i simulate the same..Smiley Happy:)
i was always keep delay inside loop and hereafter i will not do the same for serial write..
(3,563 Views)
