daqmx
Try this.  I added the DAQmx Wait Until Done VI with a timeout of 10 seconds.
Message 11 of 18
(1,675 Views)
hey crossrulz..
thanks for reply... i tried your vi bt i do not work and gives error.. i am giving 10 KHz square wave as input clock and port are connected to fix supply to show binary "10101010".
i attached error message here. plz help me out here..
Message 12 of 18
(1,639 Views)
hello..
i also tried my code without external  clock and i am getting output. so plz tell me wht might be wrong here...
regards,
Dharak
Message 13 of 18
(1,610 Views)
Have you connected your clock signal to the right pin ?
What card and what pin on that card are you using?
Message 14 of 18
(1,603 Views)
i am using pci-6534.  and i am giving clock via signal generator and i connected it to PIn PFI 2 and also tried PFI 6.
Message 15 of 18
(1,599 Views)
As far as I can read from the documentation, the PFI6 (Port5/line2) is output, so that would not work.
Can you then verify that you have connected the signal generator to port4/line2 (PFI2) ?
You can use that as an input port also, so make a small test vi that reads port4/line2 and see if it changes in a known pattern and rate. Set the signal generator to a low frequence so that you can monitor it.
How many samples have you requested and what have you set the timeout to?
Message 16 of 18
(1,586 Views)
hey all...
now my application is working.... thanks to every one for helping me out
Message 17 of 18
(1,563 Views)
hey all,
i had some issues with my function generator so problem was occuring to generate clock.
--> now i have to check at what maximum rate i can acquire data and update graph.So plz tell me how to proceed for this task. and plz share document regarding it.
regards and thanks,
Message 18 of 18
(1,554 Views)
