daqmx read
Hai,
          I want to read a pwm signal and calculate its frequency and duty cycle using DAQmx in labview. Can you please suggest the block diagram of how to implement this functionality. Please do the needful. Thanks in advance
(4,521 Views)
Did you look at the search results that were offered when you attempted to post this question?  There are many posts on this, with examples.
To learn more about LabVIEW, I suggest you try looking at some of these tutorials.
(4,518 Views)
It's needful for you to provide more information. What is the hardware that you have?
(4,517 Views)
                  The attachments are for generating PWM signal. Can you please send some VI to read a pulse width of a PWM signal
Thanks in advance
(4,452 Views)
(4,419 Views)
There are multiple examples that ship with LabVIEW for measuring pulses.  Help > Find Examples...  Then search for "counter" or "pulses".  You'll find the VI called Counter - Read Pulse Width and Frequency that Ray R. linked along with many others.  Always look through LabVIEW's Example Finder first.  It's filled with good examples and it's a great way to learn.
(4,408 Views)
