daq assistant sample rate for pulse width measurment
Hello all. i want to measure pulse width of a digital signal of around 1KHz via DAQ assistand digital pulse width vi. i need to measure Pulse width about 100hz.
i set 1  sample on demand and in any of other timing method like implicit for continues measurement i met to error. it make me frustrating that i could not measure a measurand jut at 100 hz.
i use Daqmx and windows 7 sp1 and labview 2012.
thanks
(4,136 Views)
Well the first thing that comes to.mind is that if you are doing a pulse width measurement you should be using a counter.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,129 Views)
Accepted by JavadKarbas
Ok i find the solution it is better to see the example and not to use daq assistand and use raw functions .
Counter-Read Pulseand Width and Frequency ( continuous).vi
(4,103 Views)
There you go.
Mike...
PS:you.marked the wrong message as the auction..
LabVIEW Champion
(4,083 Views)
