daq assistant elapsed time terminals different type
I have connected a relay to one of the digital outputs. I setup DAQ Assistant to actuate a valve with the relay. Now, I want to control the valve to be actuated every .....lets say 20 seconds, until I stop the program. What I would need is to change the state each 20 seconds. I tryed to use "Elapsed time" function but when I try to connect "Time has elapsed" to "Data" on the DAQ Ass. it reports different type of data. What would be the easy and clean way to use a "timer" to actuate a relay on a fixed and periodic time base? Thanks in advance !!
I am attaching a pic of my horrible test...
I am using Labview 2009 Student Edition.
(3,878 Views)
Post the VI.  Post more of the error description.
Looking at your screenshot, it looks like the dashed line going into the DAQ assistant is a bit thicker than the one coming out of the Elaspsed Time VI.  It's probably expecting a 1-D array of booleans.
You might just have to build the scalar boolean into a 1-D array of booleans.  Or configure your DAQ assistant differently.
(3,870 Views)
But if I build the scalar boolean into the array, how would I change the stat from the "Elapsed time" output? Actually, I would need to change the state from high to low each time the counter expires. Attached is the vi.
Thanks!
(3,833 Views)
Accepted by topic author Icarus7
Put a Not in there as well.
(3,823 Views)
Thanks, could you please post the VI? What version of LV are you using? I don't get the same array after the logical not.
(3,809 Views)
That's a VI snippet saved back to LV 8.6.  just drag the image from Internet Explorer to your block diagram.
(3,795 Views)
Thanks a lot for your help! This is exactly what I was trying to do!
(3,781 Views)
