daq asisstant flowmeter sensor
Hi sgirgin,
that's not possible - when you follow the advices of your flowmeter manual!
It will output at max (supply voltage - 0.5V) and supply voltage should not exceed 28V…
Is your scope configured correctly? Is ALL the wiring correct?
Message 11 of 14
(1,743 Views)
Actually i did not use a power supply i wired sensor supply cable to oscilloscope + probe.
Message 12 of 14
(1,727 Views)
That makes no sense at all. The sensor requires power to operate. Why wouldn't you want to do that? It sounds like you are just making up the connections and not reading the directions.
Message 13 of 14
(1,721 Views)
Hi sgirgin,
So you didn't read the manual (or you still don't understand what it says). And you didn't contacted someone with same basic eletrics/electronics background to assist you.
I suggested both last year…
Message 14 of 14
(1,711 Views)
