dLL made using LabVIEW called in NUnit shows error
I created a simple VI with string input and string output in LabVIEW. I created a .dLL build specification. Once I build the .dLL file, I try to call it from NUnit to run the simple VI. I get this error - "System.BadImangeFormatException : Could not load file or assembly or one of its dependancies. The module was expected to contain an assembly manifest. "
I have to create .dLL files to run from NUnit as test platform. Will I be able to do it - Looking at previous posts, it sounds like it is not possible?
(3,125 Views)
Does anyone have an answer for question above?
(3,108 Views)
What is NUnit? For a LabVIEW dll, you have to have the LabVIEW run-time installed. Is it?
(3,105 Views)
NUnit is for testing .NET assemblies. You cannot directly test LabVIEW DLLs with this since they're not .NET assemblies. Unless, that is, you write a .NET assembly wrapper for the LabVIEW DLL.
(3,090 Views)
