CMU200 SaveRecall
Hi, All
Does anyone can teach me the specific remote instructions to recall CMU200 setup by labview drivers?
I tried to recall the setup by using labview codes (remote mode), for example: Initially it is in GSM900 mode, and I
want to switch from GSM900 to WCDMA by  running the labview, "SaveRecall" Vi.
Right after that, the display of CMU 200 switches from Local to remote mode.
The message pops on the display "seems" showing that I recall the setup successfully (no error). However, when
I switch Remote mode back to Local, the setup still stays in GSM900.
I'm wondering  whetehr anyone has the same problem as I have.
thanks.
Kevin
(3,157 Views)
Hi Kevin,
Have you tired using the drivers provided by Rohde & Schwarz? If you go the download site, there are instructions on how to use the drivers. I do not have access to the instrument and am not sure if the drivers would work. I hope this helps.
Thank you,
Simran K
(3,132 Views)
Hi. Simran K
thanks for replying my post. I download the CMU200 labview driver provided by Rohde&Schwarz. It is called "rscmu200".
I think I just need a specific instruction which guides me how to use those Vis. I do check the office website, it doesn't provide
details about how to use them. Also the provided application examples are coded by labview 5.1, I wasnt able to open them with
my current version 8.5.1.
kevin
(3,119 Views)
Hi Kevin,
This driver is not supported by National Instruments. I would recommend contacting Rohde & Schwarz for details and an upgraded version of the driver.
Simran K
(3,103 Views)
