custom scale in labview graphs
in my application I need a graph that plots the x-axis in a custom scale. It is a time axis which should be linear up to a predefined positive number x and after that logarithmic. Is it possible to change the graph itself to do that - or is it better to rescale the data before plotting?
Thanks, Sebastian
(3,458 Views)
Hi Sebastian,
I don't think you can scale graphs like that. You might want to use an XY graph, then you can provide the X Axis that the data is plotted against. Go to Help>> Find Examples...>>Building User Interfaces>>Displaying Data>>Graphs and Charts for examples of using XY graphs.
Regards
Jon B
NI UK & Ireland
(3,447 Views)
See reply #4 in this thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=205891&jump=true
for an over-kill solution Smiley Surprised
Just skip the picture control stuff and use the "markers" property of the X-Scale.
Ben
(3,441 Views)
