custom picture ring: disabling the popup menu
I have custom picture ring controls -classic ones- and they work fine when clicking the increment and decrement arrows, however clicking anywhere else on the picture will cause a small popup to appear -like the ring menu control- which shows all pictures. I'd like to disable this during runtime; how to achieve?
 Im on Labview 8.6
Message Edited by _Faust on 03-22-2010 08:15 AM
Message 1 of 10
(4,131 Views)
Hi Faust,
one way is to use an event structure to catch & cancel the mouse-clicks. Do you speak of left-clicks or right-clicks?
Message 2 of 10
(4,122 Views)
Yes this works fine for right mouse clicks, but in this case I'm referring to the left mouse click on the control.
Snippet attached to shwo what I mean. I want this popup NOT to show and the user only to use the increment/decrement buttons.
Message 3 of 10
(4,097 Views)
Hi Faust,
what happens when you place a transparent decoration over the pictures of the ring (but not over the inc/dec arrows)?
That should do the trick of prohibiting the user to click the picture ring...
Message 4 of 10
(4,090 Views)
It is  a no-go unfortunately. I've tried pasting a transparant PNG over it. Wont work.
As a matter of fact I've found out that the area that responds to the left-mouse click is also the maximum bounding box of what is visible of the picture. I.e. I tried making it very small, resulting in my button disappearing :'(
Any other suggestions?
Message 5 of 10
(4,081 Views)
Hi Faust,
my suggestion was to use a decoration from the decorations palette (and make it transparent), not to paste a PNG...
Edit: see attachment for an example...
Message Edited by GerdW on 03-23-2010 12:11 AM
Message 6 of 10
(4,079 Views)
Would you mind saving it for LV 8.6?
Really curious about the solution. I'm probably being n00b again 😉
Message 7 of 10
(4,076 Views)
Accepted by _Faust
Hi Faust,
it's just a picture ring with a decoration on top, but here you go...
I only set the inner area transparent and left the border of the decoration in black so you can actually see the decoration...
Message Edited by GerdW on 03-23-2010 12:15 AM
Message 8 of 10
(4,074 Views)
AAAAAAAAHHHHHHHHH yeah it finally got through to me what you meant. BRILLIANT.
I was still busy in the customize control VI.
Maybe a bit of a weird solution but it works perfectly THANK YOU.
Maybe in future LV version an option for disabling this would be ok -just as it is available for the RMB-
thanks again!
Message Edited by _Faust on 03-22-2010 06:15 PM
Message 9 of 10
(4,072 Views)
Hi Faust,
that's what the IdeaExchange is good for Smiley Wink
Message 10 of 10
(4,068 Views)
