custom control windows xp design
Hi there!
I am looking for controls, indicators, slides, graphs, listboxes, com port selectors with a windows XP design.
Is there a library in NI website?
Charly
LabVIEW 8.5 Windows XP
It's always sunny in California! Certified LabVIEW Associate Developer!
(3,079 Views)
The example Vi you posted has some in it.  You have the System submenu under the controls pallette which has a significant portion of them.  You can manually create custome controls to simulate the look and feel for some other, such as plots.  Everything you listed in the Systems submenu with the exception of graphs.  You can use a ring terminal or enumerated data type for the COM selector (unless you want the NI-VISA reference, in which you'll have to create a custom control).
(3,078 Views)
Hi Matthew,
I found front panels controls from Inventeering at http://zone.ni.com/devzone/cda/epd/p/id/4777 and I wonder if there is an equivalent library on Ni website but with windowsXP-like controls.
Thanks for your post
Charly
(3,072 Views)
You need to define what you think of as XP-like controls. Post some images. The LabVIEW system controls for buttons, numerics, tabs, etc., look just like the buttons, numerics, tabs, etc, that I see in other XP programs.
(3,049 Views)
