Error 56 Occurs When Using TCP Read.vi
TCP Read gives Error 56: The network operation exceeded the user-specified or system time limit?
TCP Read in my application in not reliable. It works sometime, but it fails some other time. I tried to read just 1 byte, and set time out to be 1 min, I still get error code 56. What could cause this problem?
(4,189 Views)
Most of the time it is due to a poor implementation of TCP-IP and the protocol implementation ontop of that.
There can be several causes.
Once the device we talked to could not handle the network traffic, resulting in several TCP-IP retries (part of TCP-IP) and showing the result only after minutes. There was loads of traffic on the network and the device was overloaded with traffic it shouldn't even been listing to. Solution was a router.
It could just as easily be something else.
Please post a screenshot or code snippet that shows your implementation and we can give you pointers.
André
André (CLA, CLED)
(4,177 Views)
How good is the TCP connection between the two computers? Do some line testing. Could be a bad adapter, bad cable, duplex mismatch, corrupt NIC driver, etc.
You might also want to sniff some of the traffic (e.g. using ethereal (http://www.ethereal.com/)).
(4,175 Views)
