cursor triggering waveform
Hi everyone,
I'm trying to do a triggering of a waveform with two cursor one for start and other for finish , so if i get the position of the two cursors ,i want to get a subset of the first graph in another graph ,any idea of how i could do that please ?
i've joined a picture of what i want to do .
Message 1 of 22
(5,302 Views)
Keep the two indices in a shift register and  use "cursor release" events to update the cursor position ("cursor index" from property nodes or "PointIdx" from the event data node), followed by taking a subset for the second graph (sort the indices first). Make sure the cursors are locked to the plot.
Message 2 of 22
(5,285 Views)
This old example (posted here) should get you started. Just graph the subset instead of taking the mean. Easily expandable for even more cursors.
Message 3 of 22
(5,282 Views)
Thanks for your reply i'm trying to do the same and instead of the mean i do a graph . but i have a problem how can i get the of block of waveform to get the active cursor and cursor index i don't have the same in property node of my graph .
please find attached my Vi
Message 4 of 22
(5,250 Views)
First of all, the cursors need to be locked to a plot (instead of free dragging). All the properties are right there, you just need to select them in the right order. You also probably want to have a small wait inside that loop.
Simply create a property node that has the items as in my example. Make that "active cursor "write" mode, and the rest "read" mode. To get the cursor index, you need to go right from the cursor into a new submenu.
Message 5 of 22
(5,244 Views)
sorry but what do you mean by the cursors qhould be locked to a plot ,and in which part of my diagram ?
Message 6 of 22
(5,241 Views)
Hi nasnas,
what about reading the LabVIEW help?
Message 7 of 22
(5,234 Views)
Thanks GerdW ,now i understand the difference
Message 8 of 22
(5,225 Views)
I have a question about the cursors : i'm wondering if it's the same as triggering (like in an oscilloscope apply some impulsion to my signal at a certain threshold)
Message 9 of 22
(5,216 Views)
Hi nasnas,
A cursor is no trigger…
Message 10 of 22
(5,208 Views)
