cursor selection not working-bug?
hi i've the following problem. if u can find out please try the same
  1. created 3 cursors for an XY graph
  2. select one or many cursors from the legend. try to move the cursors using the '' tool. repeat this again
the cursor selection is unpredictable!!
Renn
LV 12.0f1 (64 bit)
Kudos always welcome for helpful posts 🙂
Message 1 of 20
(4,497 Views)
Hi Renn
Thanks for your post, I've tried the same and can't get the issue you described, it may be because I'm using 32 bit LabVIEW. I'll try test this on a 64 bit machine and let you know if I get the issue. Also when did this issue start, and has it worked fine before? It may something else interfering.
Dan
Daniel Harryman MEng
CLA, CPI
Message 2 of 20
(4,473 Views)
Thanks Dan
installed f3 Patch and its working!
but, i wonder this is not mentioned here: http://digital.ni.com/public.nsf/allkb/2F8112CC78A524FC86257A93006EA241
RENN
Message 3 of 20
(4,470 Views)
Hi Renn
Great to hear your issue has been solved. As for why it's not listed it may be because it's quite an obscure issue not listed as a major update. Alternativly solving one of the other issues listed in the patch may have had a knock of effect and fixed the issue you were having.
Dan
CLA, CPI
Message 4 of 20
(4,461 Views)
good.
thanks Dan
Message 5 of 20
(4,450 Views)
Hi Dan,
i have selected Cursor 0
then i clicked near 7, then using the navigation button (on the right side), i've increased the Y value. Cursor 0 is selected but, the Y value of Cursor 2 is incremented.
Many Customers are having problem with this. Please help.
RENN
Message 6 of 20
(4,427 Views)
Can Anyone help me with this?
Message 7 of 20
(4,397 Views)
Hi Renn
Sorry for my late reply. I’ve downloaded your code and seen the issue you’re having. I'll confer with some colleagues about this but it sounds like a corrective action request that will need to be passed to R&D. I’ll update you as I find out more.
Dan
CLA, CPI
Message 8 of 20
(4,387 Views)
Thanks Dan.
i wonder, this exists in most LV versions. checked LV8.0, 2010 and 2012
Message 9 of 20
(4,372 Views)
Hi Renn
I’ve been able to get the same issue you’re having from my own code and not just by copying yours. This means it’s a bug in LabVIEW and will be passed higher up. Sadly this might not be a quick fix but I will post a link up here to let you know the status of this bug once it gets filed.
Dan
CLA, CPI
Message 10 of 20
(4,346 Views)
