ctrl val get reference returns refnum of zero
I am using 'ctrl val get' in a vi.  The value it is getting is a cluster of references, the references are being returned all with a value of zero.  Is there a prohibition against using 'ctrl val get' with references?
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
(3,091 Views)
I have done similar and it worked.
Wire through your error cluster and look to see if there is an error code to give you more info.
Ben
(3,085 Views)
Yes the error is an invalid object error 1055
I have posted the error screen shot.  It refers to the property node but if I probe the cluster it shows all refnums => 0 are zero
(screen shot has the same name, but it's updated from the last one)
-Regards
eximo
Neuronetrix
(3,079 Views)
It's a different problem, the ctrl get val seems to be working fine, the VI that the reference cluster is being called from has zero's for all of the cluster values.  So, I guess the question I should have been asking is, why all the reference values are 0 in this other vi.
-Regards
eximo
Neuronetrix
(3,074 Views)
Accepted by topic author eximo
Adde a probe earlier to see whcih ref was invalid.
Ben
(3,073 Views)
