crossbow
I downloaded the Crossbow drivers and examples. There are multiple files in read folder for each sensor. For example, I'm using MTS 300 and there are Read (MTS 300, N nodes, Npoints), (MTS300 Nnodes, 1 Points).VIs..
What is the differece between nodes and points? If I want to have two micaz nodes, both send MTS 300 Data, which subvi should be used?
Thanks for you help in advance! 🙂
Message 1 of 1
(2,323 Views)
