creating file
in my program i use code to create folder and there is no problem but when i create an installer and install the app on another system when i run the application there is no new folder in selected path. what is the reason?
(3,478 Views)
Can you show us the code you use to create a folder?
Additionally, can you tell us the path you want the new folder be in?
Windows does not allow to create paths at some certain places (if you are not admin).
(3,466 Views)
section about creation file
(3,405 Views)
I changed install directory and now it is ok.
(3,401 Views)
Accepted by topic author h.sepah
So it was Windows based issue.
As I said, have in mind where you install your applications.
I suggest installing your application to the program files but keep all configs, temps, and other stuff that you want to write to in Pubic User folder.
(3,377 Views)
