I attached datasheet of current sensor, LEM HO 100-s-0100 model
I need to measure change in voltage of current sensor while passing trip Voltage to current sensor.
I connected as per they mentioned connections, ie positive , negative, Vout , resistance.
Plz go through once Datasheet, you will understand.
Sravankumar Atla
CLD || CTD
