creating event dll
I creating a dll warpper to control ASIO drivers for sound cards. I want to generate an event on the buffer switch so LV can do the work needed.
I finished a first version using a fast while loop in LV, but I think that generating a event is a much elegant solution.
The problem I have now is to compile my code!! Indeed, I found some topics how to generate events from my dll. I have included "extcode.h" and some other stuff from "C:\Program Files\National Instruments\LabVIEW 8.5\cintools"
Now Visual C++ 2008 cannot link the functions :
Error    1    error LNK2028: unresolved token (0A000295) "void __cdecl PopulateStringHandle(struct LStr * *,char *)" (?PopulateStringHandle@@$$FYAXPAPAULStr@@PAD@Z) referenced in function "public: void __thiscall DriverCluster::OnBufferSwitch(long,long)" (?OnBufferSwitch@DriverCluster@@$$FQAEXJJ@Z)    DriverCluster.obj    win32dll
Thank you for your help and I hope it's not a too stupide question Smiley Sad
Marc
Message Edité par MarcC le 12-11-2008 08:48 AM
(3,429 Views)
Accepted by MarcC
I found the solution, I just had to had in "used libs" the *.lib present in the folder cintools.
Sorry for flooding
Marc
(3,420 Views)
I'm looking to do the same thing trying to use ASIO in labview did you send the VI/dll to Labview?  How does one get a copy to try it out?  I would love to be a beta tester for this DLL.  I'm not sure why Labview still hasn't made asio access in labview yet.
(3,387 Views)
I cannot release the driver for the moment, I don't think my company would approve that I give the work I'm paid for... But to do the trick, you just need, the file asio.h from Steinberg. Then I found on the code-project, an exemple using asio driver in a c# code. Then you just need to creat a dll, some LV code and it over.
Right now I just doing optimization.
Good luck, Marc
(3,358 Views)
