creating enum from strings[] list
I have many items need to add to enum. so add it one by one is wasteing time .
Do you have another way ?
Message 1 of 11
(5,910 Views)
I can not to change the strings[].
such as this.
Message 2 of 11
(5,909 Views)
you can use a string combo box
Message Edited by Harold Timmis on 05-14-2009 11:06 PM
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 3 of 11
(5,884 Views)
Ya u can use Combobox and ring text, I have the programme to programatically populate the enum,give me some time to find that one.Smiley Happy
http://forums.ni.com/ni/board/message?board.id=170&message.id=131315 check this link for more info
Message Edited by Baji on 05-15-2009 08:44 AM
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 4 of 11
(5,879 Views)
I would advise you  to use the Variant To Control tools from LAVA. They have an example VI to convert an array of strings to an enum (typedef if you want).
Ton
My LabVIEW Ideas
Message 5 of 11
(5,852 Views)
Thanks Ton, I have download the tools form LAVA. But I have not find the Get Defalut Data form TD_ogtk.vi when I run ArrayToEnum__A2E.vi.
Would you supply the vi to me?
Message 6 of 11
(5,843 Views)
Message 7 of 11
(5,840 Views)
Its attached here....Cheers Smiley Happy
Place the folders in: C:\Program Files\National Instruments\LabVIEW 8.5\user.lib\_OpenG.lib
Message Edited by JK1 on 05-15-2009 01:14 AM
Message Edited by JK1 on 05-15-2009 01:15 AM
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
Message 8 of 11
(5,814 Views)
These VIs are part of the OpenG toolkit a valuable Open Source set of VIs.
You can install them with the (free) VIPM.
Ton
My LabVIEW Ideas
Message 9 of 11
(5,798 Views)
Old-Timers Trick:
Start with a ring control and write all of your strings to it. Then right-click and choose replace and naviagte to a enum. The enum will inherit all f the strings from the ring control.
Have fun!
Ben
Message 10 of 11
(5,774 Views)
