create big icons
Hi everyone,
I'm trying unsuccessfuly to create a big icon (2x3 cm) from a JPG data.
Labview needs some 4 files to create an icon. I used a third software (iconworkshop) to create these files. It worked well and LV accept them.
But the problem is, the only formats I see when creating an icon with LV is 32x32 and 16x16. Thus the created icon is too small!
Is there any way to make it bigger ?
Best regards
Kabanga
Message 1 of 11
(4,812 Views)
I dont think so. Smiley Sad
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 11
(4,797 Views)
Hi Kabanga,
when you start to ask for icon sizes in cm (!) I would suggest to go to lower screen resolutions...Smiley Very Happy
Just joking...
Message 3 of 11
(4,787 Views)
When they get that big are they still an icon?  Seriosly though, EasyPicture2Icon will make them up to 48X48.  I believe that I got it from Download dot com.  Hope that helps.
Cheers!
Jim
LV 2020
Message 4 of 11
(4,774 Views)
Hi Jim,
the point is: LV only supports icons in sizes of 32×32 and 16×16 points...
Message Edited by GerdW on 04-29-2008 02:25 PM
Message 5 of 11
(4,770 Views)
Hi Gerd,
I didn't know if LV8.5 had added big icons for some reason (absurd resolution monitors? Smiley Very Happy )
Jim
LV 2020
Message 6 of 11
(4,762 Views)
Hi Gerd,
I wanted simply people to have an idea of how big I want the icon to be Smiley Very Happy
I think it's a pitty that LV doesn't allow doing bigger icons !
Is there really no way to do bigger icons? even with LV 8.5. I didn't try it !
Best regards
Kabanga
Message 7 of 11
(4,756 Views)
with  iconworkshop you get even bigger icons.  The problem is with LV !!! why are they limiting that to 32x32 and 16x16 ?!Smiley Sad
Best regards
Kabanga
Message 8 of 11
(4,749 Views)
Hmmm... As far as I can see, LV supported from 16x16 up to 256x256 pix:
(at least LabVIEW 8.5.1)
best regards,
Andrey
Message 9 of 11
(4,732 Views)
thanks for the tip!
the option is also in LV 8.5
Best regards
Kabanga
Message 10 of 11
(4,713 Views)
