create a delay when a change occurs
Hallo ,
I would like to know how a delay can be created when i change the value of a pre defined control . The range control is a prefedined option that allows me to change the sensitivity . since it takes few seconds for the new sensitivity to be set i would like to create a delay when this value is changed . Kindly help me on this .
thanks and best regards,
(3,036 Views)
Store the control value in a feedback node.  Compare the current value with the previous value.  If not equal, then a wait function inside a case structure can delay your code.
(3,032 Views)
Thanks a lot for your reply .I have implemented what you said.  Unfortunately my hardware is facing some issues and i cannot test it right now.
Hope it works .
Thanks once again .
Best regards
(2,963 Views)
Yes.  That is exactly what I was saying.
Good luck getting the hardware working again.
(2,957 Views)
Thank you 🙂
(2,945 Views)
