creat database automatically using labview?
I want to creat a database automatically and then wirte data to it  sevral times?Can sb give me some advices or examaples?I have no idea about this aspect.I always see that use microsofte to creat a databsefile  ,and cann't find the examples that creat database files automatically........
The engineer told me that he cann't give me support if I didn't by their   databse soft.I am so sad and worried.
(4,326 Views)
A lot depends on what your database is.  You can try this:
http://www.w3schools.com/sql/sql_create_db.asp
If that doesn't work, Google your specific database provider to see how you can programatically create the database.
(4,323 Views)
You may  find this link will helpful https://www.ni.com/docs/en-US/bundle/371525a/resource/371525a.pdf . Its not so difficult job you can do it in less than a hour. Don't worry.
Silver_Shaper | CLD
(4,310 Views)
There's a fantastic LabVIEW API for SQLite that you could use.  I've tried making a new database in Access, but never succeeded.  I didn't spend too much time on it, though.  Here's a quick example of how to make a SQLite database with the aforementioned API.
Jim
(4,303 Views)
