Reading data at different frequencies and writing to TDMS
I am reading a data stream through EGD and writing it to a TDMS file. However, the data stream is made up of variables sent at 100 Hz, 10 Hz and 0.1 Hz. How do I split the data steam up to read at different frequencies? I also need to reset the TDMS file periodicaly to avoid excessive file size or reaching max limit size of file and data being lost.
(2,049 Views)
Hello TGL,
To help with your query it would be good to know a bit more information, would it be possible for you to attach your code? That way I can have a good look at it and suggest the the best ways to accomplish your goals. Also have you heard of the Split Signals Function? This could be of use in your VI.
Regards
David B
National Instruments UK
(2,026 Views)
