crash LV2013 ?
Can anyone confirm this behavior? (LV2013 for me)
same behavior with 2012 or/and 2011 ?
thank you all.
Message 1 of 14
(4,668 Views)
No crash for me in LV 12.0f1 (32-bit).
Jim
Message 2 of 14
(4,657 Views)
thank you jcarmody
someone with LabVIEW 2013 ?
Message 3 of 14
(4,652 Views)
I tried it in LabVIEW 2011 and 2012, and it does not crash in those versions, but it reliably crashes in 2013.  I reported this to R&D in CAR 424308.
Message 4 of 14
(4,617 Views)
Accepted by topic author ouadji
Hi ouadji,
We are already aware of this CAR (there is another CAR # for it 408955). The crash occurs when you are not using the autotool and you edit comments. For the moment the workaround is to use the auto tool for editing comments, we are investigating the crash. The crash only occurs in LabVIEW 2013.
Thank you for reporting it,
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
Message 5 of 14
(4,600 Views)
CMal , Jeff-P ... Thank to both.
(This bug occurs in the file label.cpp : Label.cpp(752) : DAbort 0xBC0BF185)
This problem is already known (CAR 424308/408955).
ok.
Message 6 of 14
(4,579 Views)
@Jeff-P wrote:
Hi ouadji,
Jeff Peacock
Please no! I can't work with the Auto Tool on!! Smiley LOL
Rolf Kalbermatter  My Blog
Message 7 of 14
(4,520 Views)
Some observations:
With VIs created with LV12.0f3 then opened and saved in LV13.0, the crash does not occur. I've tried this with ~20 VIs.
If a text box is created as a bookmark in LV 13.0, the crash rarely occurs. However there is strange behaviour in that you have to click in the text box twice to be able to edit it.
As an alternative workaround, since I too dislike autotool, I'll create VIs from all my templates in LV12 so I can easily make a copy and open it in LV13.
Using Win XP 32bit
Message 8 of 14
(4,511 Views)
@MaxCrunch :
"However there is strange behaviour in that you have to click in the text box twice to be able to edit it."
+1 ... After the first click, the cursor is like "frozen" in the text box. (LV2013)
The cursor is no longer in the text box, but inside the box there remains a "frozen" cursor
Message 9 of 14
(4,491 Views)
Yes, having to use the auto tool may mean no LV2013 for me until it is fixed.  It drives me crazy.
Message 10 of 14
(4,485 Views)
