covert to hex
Hi
I have question
I have string char = 111bf081 and I want to covert it as hex format and this what it should be 111B F081
how can i do that in labview 2009
thanks
(3,501 Views)
I divided the string in two so I had 2 strings 111b and f081. then used hex string to number on each string. This was in LV2010 tho as I dont have access to 2009
hope it helps
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(3,499 Views)
Accepted by topic author Elyan_wisam
Hi Elyan,
you should really learn to write more detailed questions.
Two possible solutions to your problem:
(3,494 Views)
Hi
I divided  the string in two so I had 2 strings 111b and f081 like you said , and I used hex string to number on each string
see picture attach , but i did get what I what 111b f081
(3,492 Views)
Hi Elyan,
- you only converted the lower 16bit number of your 32bit hex number. Is there a reason for?
- you didn't change the display format of the number to "hex display" (right-click the indicator)...
(3,486 Views)
thanks
(3,479 Views)
