03-06-2012 02:36 AM
Hi
I have question
I have string char = 111bf081 and I want to covert it as hex format and this what it should be 111B F081
how can i do that in labview 2009
thanks
03-06-2012 02:46 AM
I divided the string in two so I had 2 strings 111b and f081. then used hex string to number on each string. This was in LV2010 tho as I dont have access to 2009
hope it helps
03-06-2012 02:57 AM
03-06-2012 02:58 AM
Hi
I divided the string in two so I had 2 strings 111b and f081 like you said , and I used hex string to number on each string
see picture attach , but i did get what I what 111b f081
03-06-2012 03:05 AM
03-06-2012 03:17 AM
thanks
