corrupt llb
nicophenix
Member
corrupt llb
Message contains an attachment
Help!
I get the error "an error occured while listing the contents...." when opening a VI Library. Is there any way to recover the contents or some of the contents?
Thanks in advance for your help
4 REPLIES 4
demux
Active Participant
Re: corrupt llb
Hi there,
I think this problem is solved in the meanwhile. Am I mistaken Nicolas?
Wouter Van Hoof
AE
Highlighted
nicophenix
Member
Re: corrupt llb
ok it's solved by NI Belgium
chrisger
Active Participant
Re: corrupt llb
hi there,
sometimes i have serious troubles with corrupted llbs. i use them in almost all apps i create because i can bundle and distribute a functionality in a single file (like handling of DAQ, datafiles etc...). the trouble is, when i rename a vi in win explorer while its not in memory and other vis of the same llb are in memory, the vi or the whole llb sometimes get corrupted. thats quite anoying. as i use visual source safe i have a backup in most cases. but anyway, i lost data more than once.
what was the problem with your llb and how was is fixed? are there any fixes in LabVIEW > 7.1.1?
the problem occured on several machines with LV 7.1(.1) under Win XP Pro SP2.
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
demux
Active Participant
Re: corrupt llb
Hi there chrisger,
If you mail your corrupted .llb to the NI support mailbox of your country they should be able to retrieve a big part of the content. That's the way nicophenix did it and we were able to retrieve the information that did not get corrupted.
Wouter Van Hoof
Applications Engineer
NI Belgium
