correct # of data points
I can't seem to get the right amount of data points...I don't know if it's my timing or the way I'm aquiring data. I want to run 30 cycles at 1hz and have it take readings 100 times per second. Hence, I should get exactly 3000 points. When I look at my data file, the numbers are all over the place.
(2,237 Views)
(2,235 Views)
