convertion to integer from array and logical mask
hi all.
please look at my VI.
1)i want to convert this array to 4 display. each displaywill show one element(=1 row, in this case) from the array.
    how i do it ?
2) i need to make logical mask  to those numbers. how i convert the integer number to binary and make this logical mask ?
with best regards
pro111
Message Edited by pro111 on 12-02-2006 05:41 PM
(3,634 Views)
someone ?
(3,621 Views)
  1. To extract individual array elements, use "index array" (resize as needed).
  2. To mask an integer, simply use "logical AND" with your mask value of the same representation. It will do a bitwise operation.
Attached is a simple example (LabVIEW 8.0).
(3,607 Views)
Hi pro,
I did not follow you and came up with another example while Christian was doing his.
This is my guess at what I thought you were asking.
Ben
PS Christian, I am not trying to side step your example. I figured if I drew it up I should post.
PPS talk about a post collision!
Message Edited by Ben on 12-03-2006 12:32 PM
(3,602 Views)
many thanks
(3,599 Views)
