converting decimal string to a number
@RavensFan wrote:
Did you try wiring a False constant into the top of the functions you are using now?  Like I said in message 16?
There's not a single boolean constant in the code ...
Qestit Systems
Certified-LabVIEW-Developer
Message 21 of 33
(2,586 Views)
Exactly.!!!! If a False constant was wired into the top of the Fract/Exp String to number function, it wouldn't be using the default value of True which uses the system decimal, which for the poster is a comma rather than a period. It needs to be a period based on the data that is in the string.
Message 22 of 33
(2,579 Views)
Try setting the marked input to FALSE.
/Y
Qestit Systems
Message 23 of 33
(2,566 Views)
I'm trying to put the function false, but not ta working. Its help me please I sent the VI. please
Message 24 of 33
(2,553 Views)
I don't see anyplace where you have set the input to false or where you are using a Scan From String function. You have also not posted the subVI you are using. Please post a VI with the corrections that you say you have made.
Message 25 of 33
(2,541 Views)
/Y
Qestit Systems
Message 26 of 33
(2,530 Views)
I want to thank everyone who helped me by hints at what to do this transformation. The program worked. Much obliged. Thank you.
Message 27 of 33
(2,512 Views)
One more doubt. Is to transfer the data from Labview to Matlab?
Message 28 of 33
(2,509 Views)
I would recommend just writing your data to a CSV file and then have your Matlab code read that file.
GCentral
Message 29 of 33
(2,498 Views)
I am reading my data to write the measurements file, then open in TXT. I do not know what is CSV. how to connect and which block or icon works?
Message 30 of 33
(2,489 Views)
