converting LabVIEW 8.5 to 2012
I try to convert my application written in LabVIEW 8.5 with NI-Daq traditional to LabVIEW 2012 with NI-DAQmx.
you will find the code in attachment piece
(3,521 Views)
Accepted by camilia
Are you aware of that there is very specific baord available for upgrading/downgrading requests.
http://forums.ni.com/t5/Version-Conversion/bd-p/VersionConversion
Also, a VI that is created in LabVIEW version 8.5 can be opened in version 2012 & later will recompile (upgrade) it.
Edited: Find upgraded VI with DAQmx functions in the attachment.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,520 Views)
Thank you very match you save my life.
I have a nother VI can you convert that. I try with version convertion but i have not a result
thank you,
(3,478 Views)
Find the attached VI here... but I would like to mention that you should explore NI DAQmx functions and try to learn how VIs built using traditional DAQ functions can be upgraded using NI DAQmx function.
(3,471 Views)
(3,464 Views)
Have you an idea where i can download the librairy Orbit_IF.dll and the way to install it?
thanks
(3,458 Views)
thanks
(3,455 Views)
