converting 4 bytes to float
Wow, I must be onest. I didn't expect solving of my problem so fast.
Many thanks to crossrulz. His vi works 100% correct.
Regards to all!
Vlado
Message 11 of 18
(3,744 Views)
Back again.
This time I need help with oposite conversion from float to 4 byte array.
It should be used Microchip conversion where from MSB side eight bits are used for exponent, then one bit for sign and rest of 23 bits for mantissa.
So question, how to modify attached example to get desired result?
Regards, Vlado
Message 12 of 18
(3,655 Views)
Accepted by California_J
California_J wrote:  This time I need help with oposite conversion from float to 4 byte array.
All you actually have to do is change the Rotate Left on the MSB to a Rotate Right.
Message 13 of 18
(3,635 Views)
Can you make that work for LV 2013??
I can not ID what those elements are and when I drag the snippett, written in 2015, it will not convert...
Message 14 of 18
(2,992 Views)
Here you go.
Message 15 of 18
(2,978 Views)
You ROCK!
Thanks a million!
How did you figure that out??
I have never used those structures!
VERY VERY cool!
Message 16 of 18
(2,968 Views)
It's called a snippet.
Message 17 of 18
(2,961 Views)
I got the snippet thing... The MAGIC is that structure! VERY VERY cool!
Message 18 of 18
(2,959 Views)
