convert the range
hello
i want to convert the range of 2GHz to 18GHz proppotional to o to 10V, i.e. when my input is 2GHZ that time output should be 0v and when my input is 18GHz that time my output should be 10v so for that i had make one vi with addition of sampling rate which is necessary for genrate ramp type output.
i am facing problem with not getting output according to that so plz kindly find the attechment over here and if possible then correct it.
thaks
Message 1 of 20
(3,990 Views)
Can you post the vi in 2009 version?. Also what type of signal you are acquiring and what is the Hardware you use?. Otherwise are you trying to simulate the signal and convert the Frequncy to Voltage?
Message 2 of 20
(3,985 Views)
Hope this would help..
Message 3 of 20
(3,970 Views)
thanks for reply
i am trying to genrate analog signal using daq card which is usb-6008
now i am able to convert my range but according to that range daq card is not taking input.
i chck daq card using daq assist its work in very nice manner but when i connect acroos the output of converter that time i am not getting output
thanks
Message 4 of 20
(3,962 Views)
simple interpolation:
Message 5 of 20
(3,961 Views)
thanks for reply
thanks
Message 6 of 20
(3,957 Views)
Hi hussey,
you dind't mention you need an output array!
Btw. there's a very nice Ramp function in LabVIEW, see attachment...
Message 7 of 20
(3,951 Views)
thanks but still not getting output in waveform graph i mean daq not genrate any output
Message 8 of 20
(3,946 Views)
Hi hussey,
well, there's an error shown in the error cluster... Which error is it?
Message 9 of 20
(3,943 Views)
i have attested a error picture
Message 10 of 20
(3,937 Views)
