convert the color image to array
HI , I want to convert the color image to array, but was unsuccessful,  the output U64 data is null.
Can you provide the example to me ?
I also searched this function example which does not exist in the LabVIEW examples.
(3,002 Views)
How about the Image Pixels (U32)?
Also, check the error out... This VI probably works for color images only, if you insert a grayscale image, you need to use the grayscale variant.
(2,986 Views)
Input color image, the U64 is null, NI can provide the example about colorimage to array?
(2,959 Views)
The U64 2D array is empty (not null), because the image doesn't have U64 pixel values.
See the info of the image mentioning it's a 32-bit image...
If each pixel is RGB, it's 8+8+8 bits, and the array of 32 bit values is used to return the pixels.
Set the 2D array of 32 bit integers to hex, and you'll see the numbers represent RRGGBB (or BBGGRR).
(2,956 Views)
You could use Color To RGB.vi (use quick drop) to convert the numbers from I32 to RGB.
Maybe B and R are reverted... That happens.
(2,954 Views)
(2,947 Views)
