convert string into a 1d array of strings
I attached a txt file called Percentage, on one of my messages.
I'll attach it again.
Message 21 of 34
(3,013 Views)
I found the problem, but I don't know how to fix it.
The thing is the array has only 1 column and I need to separate the data in two columns.
I need the headings in the first column and , the additional info in the second.
Just read from the txt and display it in an array with a bigger string indicator and you will see what I mean.
Message 22 of 34
(3,001 Views)
I fixed the problem the following way:
Message 23 of 34
(2,980 Views)
Are you aware that index array is resizeable? Only a single instance is needed here. There is still way too much duplicate code.
Why is there a while loop? Does the file continuously change, making it necessary to read and porcess it over and over?
Message 24 of 34
(2,976 Views)
The txt doesn't change in this vi but the system exec command's result does.
Message 25 of 34
(2,973 Views)
Is there a way to center the text in the indicator?
Message 26 of 34
(2,967 Views)
Yes, just set the font to be centered.
Message 27 of 34
(2,965 Views)
I seem to have a tab and I can not rsmove it.
How can I remove tab space and text from string?
Message 28 of 34
(2,961 Views)
Have you not even looked at the code? You have a function there that replaces tabs with spaces. Turn on Context Help and read it. You still haven't taken any of the free tutorials, have you?
Message 29 of 34
(2,954 Views)
Sorry about that. I removed the tab ans space I was adding, but the first string still has a tab in it, and I don'tknow where it is.
Message 30 of 34
(2,928 Views)
