convert string into a 1d array of strings
Save the data from the standard output.  I can't help you without that string data.
Message 11 of 34
(4,157 Views)
I did what you suggested, but still nothing.
Message 12 of 34
(4,144 Views)
Do you have the text file that you saved?  That is what I was wanting.
Message 13 of 34
(4,133 Views)
I changed the write to txt file code to this:
The weird thing is that it does not create any txt file, so that is why I don't see any data in the array.
Message 14 of 34
(4,130 Views)
I had an error.
My code is now this:
Message 15 of 34
(4,122 Views)
Its reading an empty string:
Should I read line by line, and if so, how do I do it?
Message 16 of 34
(4,121 Views)
Saving to file seems pretty pointless. Probe the input to the write file and use some error checking. An obvious change would be to simply wire the standard output to the spreadsheet string to array.
Message 17 of 34
(4,107 Views)
The thing is that I need a 2d array, with the headings in the first column and the other data in the second column.
How can I do this?
Thanks.
Message 18 of 34
(4,100 Views)
No, you did not! You need to save it with the data contained in the string as I described above.
Obviously, you don't want to split after the persiod, else it would split between the 24 and the 3, destroying your value.
(Also "/home" is not a valid finename because it contain an illegal character.)
Message 19 of 34
(4,082 Views)
You've already been told how to do this. You have not attached a copy of the actual string as far as I can tell. You've ignored the instructions on how to save a VI with a default value of the indicator. That's s basic LabVIEW skill. To repeat, run the VI so that you have a value shown. Go to Edit> Make Current Values Default. Save the VI. Attach that.
There are numerous free tutorials. Haven't you been suggested to take them? Have you?
Message 20 of 34
(4,081 Views)
